brake fluid soft lines replacement
  • tonytony
    Knee deep in poopie
    • Jan 2004
    • 3498
    Ok so i'm doing the m50 swap with the ix booster and i'm using a remote reservior, well the lines are too short since it's from a DSM. Wondering if fuel lines can handle brake fluid without deteriorating in a month? thanks
  • blunttech
    • 12850
    bmw sells special soft line for remote reservoirs. i dont have the part number handy but VW also sells it. just go to a dealer and ask for it.
    sales@blunttech.com
    www.blunttech.com
    Like us on Facebook
    • NickP
      • 257
      The BMW line is has a smaller inner diameter than the DSM line - it won't work.
      • NickP
        • 257
        I mounted my remote reservoir off the shock tower. There's an area where you can put a speed clip and a bolt where you can mount a simple bracket. I'll take a picture of mine this evening. But yes the DSM reservoir is a direct fit - make sure you use the grommets off the DSM MC as well.
        • tonytony
          Knee deep in poopie
          • Jan 2004
          • 3498
          so i take it the fuel lines wont work? I guess i'll try to do what nick said
          • NickP
            • 257
            I don't know if fuel lines are stable for brake fluid. Try calling up a couple of motorcycle shops.
            • tonytony
              Knee deep in poopie
              • Jan 2004
              • 3498
              thanks, i'll try that when the time comes
              • DJB
                • Oct 2005
                • 195
                BMW fuel and coolant hoses are EPDM with an aramid reinforcing fiber. That's fine for DOT-3/4 brake fluid. Other fuel hoses may not be EPDM and will probably degrade.
                BMW's flexible low-pressure brake hose -- the blue cloth-covered hose used for the clutch line -- appears to be silicone rubber.
                • tonytony
                  Knee deep in poopie
                  • Jan 2004
                  • 3498
                  thanks, very helpful info
                  • Van Westervelt
                    • 9365
                    Tony, how close are you? gonna make it to bend? Luke, aka stereo installer said he knows an exhaust guy local to you. hit him up
                    • tonytony
                      Knee deep in poopie
                      • Jan 2004
                      • 3498
                      I have to connect my brakes components, then mess witht hat heater i was bitching about when you were over, and then hook up the rest of the coolant system. Exhaust left then shifter, then go over everything then i'm good. I'll hit up luke, thanks
