Why can't I fill my coolant system all the way?
  • Purdue89E30
    • 991
    I'm trying to fill the coolant system on my '89 325i but nothing is getting into the hose that leads to the water pump or the one that leads to the top of the radiator. I'm concerned that the water pump is running dry and not circulating the coolant. I keep adding coolant to the reservoir but it just ends up going through the overflow and onto the floor so I don't know what I'm doing wrong. What are your tricks for filling it?
    "One of my top five favorite, like, cool...nerd cars"
    '89 325i-sold
    '98 528i
  • delatlanta1281
    Dart Master
    • Mar 2006
    • 10317
    dude something is wrong. the only trick is to unscrew the cap!
    Yours truly,
    Rich
    you kids get off my lawn.....
    • rede30
      • 4697
      I think you need the car running? I think i remember doing this but i am not sure.
      • AdamF 88iS
        • 2051
        Have you opened the bleeder on top of the thermostat housing? If you don't open that while filling you'll only get it about half full before it overflows.
        Adam Fogg- '88 M3
        Common sense- It's the new 'gifted'
        • Purdue89E30
          • 991
          I did open the bleed valve and I did run the engine, I drove the car around the block but it got hot very fast. The problem is that the coolant can't fill the hose that goes over the timing belt cover, there's air trapped in there and I think the pump is air locked because coolant doesn't seem to be circulating. The water pump is pretty new, I know the thermostat works. Don't know what to do, I just want to drive my car!
          '89 325i-sold
          '98 528i
          • Rob
            • 8166
            pull that hose and pour coolant directly in?
            BEERTECH
            • delatlanta1281
              Dart Master
              • Mar 2006
              • 10317
              man that is weird, Let me consult my bentley and I will get back to you!
              Yours truly,
              Rich
              • delatlanta1281
                Dart Master
                • Mar 2006
                • 10317
                Ummmm nothing.
                Yours truly,
                Rich
                • Mike325
                  • Mar 2006
                  • 3685
                  Maybe you need to pressure bleed?
                  Originally posted by Kershaw
                  • mikeedler
                    • 6707
                    like said by rob, just unscrew the hose, and pour some coolant in there. its all but too easy!
                    sometimes the M20s like to be a BE*AAATCH to fill and bleed, but that has worked for me everytime.
                    • mitch500
                      • Jan 2006
                      • 1092
                      run it and pour it in, unscrew the the bleeder untill it pisses out the top. turn car off then tighten the bleeder this is what i did when i changed my rad,
                      1988 e30 alpine white vert 5speed
                      1987 e30 325 eta
                      1983 e28 533
                      2001 x5 4.4l
                      1997 e36 M3 Alpine white 5speed
                      1991 Jeep XJ I6 4.0
                      • Purdue89E30
                        • 991
                        The problem was that the air trapped in that hose wasa higher than the bleed screw, it wasn't going to come out throught the bleeder. I solved it by running a small tube through the thermostat housing and up into the hose then carefully sucking the air out through the tube. I know this sounds ridiculous and overly complicated it solved the problem, the temp needle stays dead center when i drive now.
                        '89 325i-sold
                        '98 528i
                        • 87-325ic
                          • Apr 2006
                          • 1198
                          i was going to suggest "hand-pumping" the hose,
                          before i blead mine, i filled it with the bleeder screw open, and squeezed the big upper hoses until i heard water swishing in them..
                          then continued to fill and bleed as normal,
                          very little bleeding, and no problems.. my first time ever even draining the coolant.
