No power
  • sketchkid
    • Dec 2015
    • 165
    No power
    So today I change the o2 sensors, note the past month I've change the fuel, fuel filter, spark wires and plugs, fuel pump relay, oil change. Today I got to drive it no dealing power after 2gear noticed I do have a vacumm leak but it has no power in when I get good in 2 gear videos below, could it be the clutch, or transmission fluid that needs to be change or what?
    Sorry, we couldn’t find that page
    91 318is "under construction"
    2007 328i - daily
  • vpilarrt
    • Jun 2006
    • 2096
    Fix the vacuum leak, check the intake bellows carefully (replace if its suspect), do a stomp test for codes.
