Fuel leak from hose connecting filler to tank
  • alas
    • Oct 2015
    • 291
    Hello R3v,
    I was wondering if anyone can help me find the correct hose I need to fix this leak.
    I've discovered a pretty fast leak after filling up my e30 the other day.
    It's the hose that connects the filler hose to the tank itself.
    It looks like it is leaking either from a corroded hose or at the clamp itself. I couldn't get a good look at it but when squeezing the hose I noticed it didn't really return to the proper shape and the hose felt quite weak.
    Regardless the hose and clamp will be replaced but I'm having trouble finding a part number. Is it just a generic hose that I should buy and cut to length? Or can I find a proper part number?
    Pelican parts seems to only sell at longer lengths.
    What's the proper thickness and spec hose I should buy?
    My second concern is: will I need to drain my tank before replacing the hose?
    Any help or feedback is greatly appreciated.
    Thanks in advance!
    -E
    -ALaS
  • roguetoaster
    Biggus Tippus
    • 7830
    The hose necks down in size and can't really be made of generic hose.
    You can find the part number on realoem or bmwfans.
    You'll need to drain the tank to below the level of the nipple on the tank to replace the hose in question.
    • alas
      • Oct 2015
      • 291
      Thanks for the info. I'll check it out. I did notice the step down, but it looks like my car has another hose connecting from that neck down to the tank. (PO replaced fuel tank).
      Any idea what that OD is in the stepped down tubing into the tank?
      -E
      -ALaS
      • roguetoaster
        Biggus Tippus
        • 7830
        For p/n 16121180402 the large end od is approx 1 7/8", id 1 5/8", small end od 1 1/2", id 1 1/4".
        It's also roughly the shape of your average banana.
        • alas
          • Oct 2015
          • 291
          Super, thank you!
          -E
          -ALaS
          • roguetoaster
            Biggus Tippus
            • 7830
            Should also point out that it's quite possible for the nipple on the tank to have corroded, but it's more likely that the hose has failed.
            • alas
              • Oct 2015
              • 291
              Thanks for the heads up. Is that nipple in the same area as the hose I will replace? Perhaps I can check it quickly before working.
              -E
              -ALaS
              • roguetoaster
                Biggus Tippus
                • 7830
                Was just talking about the nipple off of the tank to the fill hose that's discussed above.
                Either way, start with removing the old hose from the tank end first to see what you can see.
                • alas
                  • Oct 2015
                  • 291
                  Ah gotchya. I was thinking of something physically smaller since you said nipple.
                  I'll update the thread once I've got further into it.
                  -E
                  -ALaS
                  • Idrisu
                    • Jul 2015
                    • 173
                    -E
                    on my e30, that hose is squishy but there isn't and leaks coming from it. I'm trying to find out why my tank overfills so quickly. when the filler neck is full and I squeeze this hose you can see the fuel left in the mouth bubble. any ideas?
                    • itsonlygeorge
                      • Feb 2014
                      • 852
                      Check your thread. I posted a response.
                      1987 325e Lachssilber w/ MarkD chip and late bumpers, Zender EVO spoiler, s3.25 LSD
                      Originally posted by nando
                      I don't think there's really strong evidence that ZDDP harms cats.
                      • alas
                        • Oct 2015
                        • 291
                        Fixed it today. Totally was that hose that reduces diameter and has a phallic bend.
                        Check out the cracks:
                        Lost about a gallon doing the work too.. [emoji850]
                        But...all sealed up. No more leak.
                        Thanks for your help guys.
                        -E
                        -ALaS
