Sunroof drain
  • BS87
    • 1606
    Sunroof drain
    ANyone have a diagram or a rough drawing, or a 2 year old ms paint scribble of the routing of the sunroof drain? i need to find a problem ( i think there is a hole somewhere along the piping of the drain, before it drains out the rear.)
  • grlaneriejr
    • 321
    why are you looking for this? where is the water backing up?
    the reason I ask is that my car used to get water inside the rear passenger footwell when it rained. there is a drain under the car that gets crimped and keeps the water in.
    is this what your car is doing?
    • BS87
      • 1606
      No, the drain is fine, it drains out the back like it should, but it also leaks in the fron a little bit
      • grlaneriejr
        • 321
        oh well, sorry. i don't know what that would be.
        you might want to look under the car on the passenger's side and see if there is a slot that is crimped shut. might be it.
        • Low Level E30
          • 1646
          How do you clear those drains? Mine are blocked.
