turn signal and flashers problem
    yesterday i noticed that my turn signals weren't working
    then today i was checking things and when i turned on my hazard flashers
    it only flashed the left side and that one was very dim. then it blew the fuse for
    the flashers. checked fuses and #4 and #24 were out. replaced both. turn signals
    worked for 3 seconds then blew fuse #4 again. the hazard flashers worked the
    same as before, blowing fuse #24 again. turn signal flasher is new. flasher
    relay is new. taillight circuit boards are clean with no corrosion. taillight
    control board was taken off and cleaned.
    any ideas?
    any ideas?
    Similar thing happened to me. It turned out to be the wires running to the rear lights. Mashed under the driver side, outer front seat foot.
    Originally posted by Andy.B
    I was born on 3/25…
