Need help with some exhaust flanges
  • Gingerrella
    • Jul 2014
    • 117
    So I finally got around to installing my MagnaFlow catback. Not as easy as I'd hoped.. I snapped all 4 bolts and finally got the exhaust off after purchasing a new dremel. Problem now is the captive flange on the back side of the cat just cracked all the way in half when I was trying to remove the bolts.
    I did some research and found a few 2 piece flanges online. Essentially two C shaped pieces with two bolt holes on each that bolt together around the pipe.
    Has anyone used these on an E30? Any suggestions on which one to buy/which one will fit?
    This is what I'm looking for, just want to know if anyone has used one successfully?
    Sent from my SAMSUNG-SM-N910A using Tapatalk
  • mikerob97
    • Jul 2010
    • 140
    have not used these, but looks like a good option. I don't see why these would not work...Good luck, keep us posted.
    Mike
    Cary, NC
    Current Rides
    1991 325iC - For Sale
    2006 M3 Cabriolet
    Past Rides
    2000 323i Touring - Daily Driver
    1994 325is (S50) - Fast Car
    1998 Z3 - Fun Car
    1986 325e (i engine conversion)
    1969 Mustang Mach 1
    • Gingerrella
      • Jul 2014
      • 117
      Ordered 3 different sizes on Amazon. (1¾-2" 2-2⅛" and 2-2¼) I'd imagine at least one of them while fit right. Fingers crossed! I'll let you guys know which one works, hopefully save some people some heartache.
      • dnguyen1963
        • Nov 2011
        • 2651
        Keep us posted and give us the Amazon item number too.
        • Gingerrella
          • Jul 2014
          • 117
          Sad news guys, they were all too big. I ventured to autozone and advanced, neither of them had anything small enough. Although the guy at AZ did tell me the flange I had was so small, it definitely isn't from a car.. idiot.
          I ended up buying a bolt together flange and with a little help from my dremel, made it work as a temp fix. I guess I'll just go to an exhaust shop and have them do some welding to fix it right.
