Why would there be fuel injector faults for all 6 injectors on an m50? I am trying to figure out why the m50 in my friend's car will not start.
All injectors have 12 volts through them with key-on. They all inject fuel, all 6 plugs wet, and the send and return lines are connected correctly. There is also 12 volts at the ecu for the fuel injectors. There is also spark, and everything is grounded very well. The crank and cam sensors are wired correctly (crank sensor checks out on ohm test, cam sensor didnt come out with the spec I had). Upon no start, I plugged the code reader in and got 6 codes all for fuel injectors. Why? I dont think they could all be bad especially if there is fuel in the cylinders.
Also, there is combustion, sometimes very violent combustion like the exhaust valve is open causing flames to shoot from the manifolds, or excess fuel is running through the manifolds and igniting somehow. Only way to describe the operation is that it's like a motor that is out of timing sequence, fuel and spark aren't happening when they are supposed to.
Any ideas?
Any ideas?
