Tough Gas Pedal
  • bimmer8604
    • 3017
    Tough Gas Pedal
    My gas pedal is really hard to push down, and the other e30s ive driven they are really smooth. I've checked my cables, and no snags, is there somethin up behind the pedal that can cause it to stick?
    Does anybody else have this problem?
    Kyle
    1988 M3, 97 840, 99 XJ
    DILLIGAF
  • Jordan
    • 12916
    Check the linkage between the pedal and the throttle cable, oil as needed.
    Check the spring tention on the throttle body.
    https://mtechniqueabs.com/
    • Spaz
      Crazy Canuck
      • 2276
      go with that.....
      a little off topic but, on chevys 3.1, 2.8 engines the same thign happens and normally its the throttle retrun spring gets streched making it stiffer so we have to rplace those offen. never sen that happen on a bmw though.
      go with what jordan said, stiffness could be cured easily by some lube.
      Cam .W '91 325is
      Spaz's 1991 Alpine White???? S52 Build Thread...
      • Sean
        • 5793
        My 87's gas pedal is as hard as a rock. My 88's is as light as the pedal in our other BMW's.
        Throttle body spring resistance feels the same to me. I think it has somehtin to do with the cord.
        - Sean Hayes
        • LikeCDoos
          • Jan 2004
          • 2522
          mine is real light where as my friends 86eta is stiff as a rock...weird
          • Sean
            • 5793
            Maybe it has to do with the pre 88's then?
            I dunno..
            Cause my 88 is still an eta..cept' a Super. :twisted:
            - Sean Hayes
            • 318driver
              • 1714
              I dunno..
              we all know its a SUPER ETA, so stop bragging, haha, I dont think i could even count the amount of times youve said it. lol. im not trying to be an a**hole, but im tired of reading it.
              90 325is
              IE stage 3s and refeshed m20....
              • Sean
                • 5793
                I dunno..
                Sorry man. Don't mean to "brag". For the reason of the post, I included it. What I was getting at was it may have had something to do with the eta engine, possibly. But, I pointed out even though it was an 88, it was still an eta.
                Sorry. :x
                - Sean Hayes
                • e30Matt
                  • 5077
                  Go to a store and buy a cable luber. Usually they're a small metal clamp-looking device with a rubber insert that has a hole for the tube you usually find taped to the side of a WD40 can. Take some silicone lube and lube the cable thoroughly. My 325 did this and that cleared up the problem.
                  • Super Eta
                    • 1884
                    mines a bit stiff too but i dont mind its doesnt bother me its just another work out and i guess you could say it evens it out for the clutch work and yea :?
                    • randomtask37
                      • 3154
                      mines pretty stiff also and ive been meaning to do something about it for a while. ill try some wd-40 tomarrow.
                      98 M3/4/5
                      • bimmerphile
                        • 3495
                        I dunno..
                        Sorry. :x
                        he's just jealous of the 70 more ft/lbs of torque :pimp:
                        • chesster6969
                          • 321
                          I just bought a new one. Got it for about $15 and the pedal feels like new.
                          Took half an hour to replace in the middle of the night.
                          Now I need to replace the auto transmission accelerator cable to get all the cables new.
                          • bwanac
                            • 3354
                            Bought a new what?
                            By the way, the pedal in my '87 eta is stiff as well. Whenever I drive my sisters 5-speed accord I am so excessive witht he gas pedal. Damnit!
                            • bimmer8604
                              • 3017
                              i just sprayed all the moving parts i could, and it feels a bit lighter, but nothing as compaired to my friends 89. atleast it helped
                              kyle
                              DILLIGAF
