Two questions please
  • ajp340
    • Mar 2016
    • 62
    I just bought the oem Mtech1 steering wheel for my 1990 325is (airbag car)how do I get the horn to operate? whats the hack?
    my reverse lights do not go on while car is in reverse, checked fuse.
    Please help me car won't pass inspection unless i fix both
  • roguetoaster
    Biggus Tippus
    • 7792
    The horn ring on the wheel probably isnt in contact as needed, possibly because of the way you have it spaced.
    For the reverse lights you should inspect the switch/connector for same as it can fall off/apart.
    • ajp340
      • Mar 2016
      • 62
      please elaborate about the horn ring, provide pics if possible
      • roguetoaster
        Biggus Tippus
        • 7792
        It's a contact strip on the back of the steering wheel that transmits the horn signal down the column. It's part of a plastic "tower" that screws to the back of the wheel.
        The better question is, how did you install spacers during the swap?
        • ajp340
          • Mar 2016
          • 62
          no spacers
          • Chrisbike
            • Mar 2015
            • 688
            I've had a mtech 1 wheel in my airbag iX. Horn worked..
            Spacer -> Wheel -> spacer -> washer -> locknut
            I'm pretty sure it's impossible to install it without at least one spacer because of the amount of thread you have to tighten everything down, you proabably already have one before the wheel from the airbag wheel.
            Build Thread
            https://www.r3vlimited.com/board/sho...d.php?t=419655
            Parts Thread
            https://www.r3vlimited.com/board/sho...d.php?t=408302
            • ajp340
              • Mar 2016
              • 62
              wheel->washer->locknut
              Thats all i have/did
              • ajp340
                • Mar 2016
                • 62
                Bump please
                • Seawolf
                  • Feb 2015
                  • 270
                  You could post some pics of what you've got and how you installed it, might help.
