Best e30 shop in CT
  • ParksMyCar
    • Apr 2016
    • 100
    Best e30 shop in CT
    Anyone know a good shop in CT. looking to have my e30 325is looked at. Has a strange idle. Sounds like it's camed some times then will go back to normal. Also has a strange knocking or clunking noise can figure out if it's the engine or tranny. Only happens when idling and clutch out in neutral
  • ParksMyCar
    • Apr 2016
    • 100
    Bump
    • M-technik-3
      • 18946
      Where in CT? It's a small but big state, NYC/Coastal Region Hartford Northeast or NorthWest?
      There are plenty of in the area.
      • Art5
        • 61
        There is a bmw shop in Waterbury that I know of, but dont remember name of it. They turbo bmws
        • ParksMyCar
          • Apr 2016
          • 100
          I'm northern ct. Somers, CT
          • SSR-125
            • Jan 2014
            • 578
            I don't own a shop, but I know about them and BMWs in general and can help you out. Im in CT as well. Im around the vernon area if you want which isn't far from you. Shoot me a PM.
            88' E30 325 24v Turbo Coupe
            91' E30 325i Sedan
            09' E82 135i Coupe (Sold)
            01' E46 325ci Coupe (Sold)
            97' E36 328is Coupe (Sold)
            91' E30 325i m52 Coupe (Sold)
            90' E30 325is Coupe (Sold)
            90' E30 325ic Coupe (Sold)
            88' E30 325is m20 Turbo Coupe (Sold)
            88' E30 325 Coupe (Sold)
            87' E30 325e Coupe (Sold)
            86' E30 325es Coupe (Sold)
            • johnt325ix
              • Nov 2013
              • 101
              Performance Imports Danbury, Ct. Very knowledgeable, very honest, appreciates the cars. Auto Technic New Milford, Ct. E30 and E34 is their main business. Hard core group of BMW enthusiasts.
              Sent from my SM-G900V using Tapatalk
              • Seawolf
                • Feb 2015
                • 270
                Same as SSR I don't own a shop but I'm 9 miles from you in Longmeadow.
                PM me if you want to come over and I'll take a look at it, smoke test is likely the first step. This'll give me an opportunity to use my newly built smoke machine.
                • ParksMyCar
                  • Apr 2016
                  • 100
                  Okay so found mostly the cause of the strang idle. Came from where the splined cast piece of the ICV mates the intake manifold. Sprayed some carb clean on the gap and idles really high. I nearly used some Jb weld to seal it. Idle has clean up a lot but still has some stumble and a tad bit of a pause when hitting the gas at idle. Drives perfect though. Any thoughts?
                  Thank you guys for the shop suggestions seawolf I may have to hit you up on that offer.
                  • Seawolf
                    • Feb 2015
                    • 270
                    No problem just drop me a PM when you're thinking of dropping by.
                    Don't JB Weld the TB elbow(s), do this if you want it to last:
                    If you want to keep the original look you can drill and tap a hole through the TB and elbow and use ptfe tape and a securing screw to seal and hold the elbow in place.
                    JB is such a hack job.
                    • ParksMyCar
                      • Apr 2016
                      • 100
                      Oh I know jb weld is a hack job. I did it the best I could. It was a Friday and needed the car Saturday. It actually didn't come out that bad. A little bit of paint and some sanding and you wound know it was their.
                      Yeah I'll have to swing by sometime. I don't know to many bimmer guys in the area.
