Cluster Problems
  • Kalimari
    • Jul 2016
    • 4
    Cluster Problems
    Like a million other posts on this forum I'm having problems with my cluster. The speedo is broken, the tabs are broken, and it seems to missing many other parts. What is my best option for fixing all of this? I've checked eBay and found a few clusters but they have the different tach. Can I buy one of those and switch the tach? If so How? What else do I need to change over? It's VDO with a replaced SI board form programinc. Any information is helpful, thanks.
  • roguetoaster
    Biggus Tippus
    • 7830
    If you get a different cluster you may need the tachometer and coding plug. Try to stay near to what you have already, so if VDO, get VDO. Don't forget to order a set of odometer gears to get the odometer working again.
    • ecsk
      • Nov 2011
      • 106
      Swapping gauge from one cluster to other is very easy, there are a few youtube video about pulling a cluster apart, there are only 3 screw at the back for the techometer.
