2.0L and 2.5L ECUs
  • TheCondor
    • Dec 2005
    • 14
    2.0L and 2.5L ECUs
    Hello everyone :)
    I'm a new member to this site/forum, and I must say I pretty much like it :bow:
    I currently own two E30s, a 2.0L and a 2.5L. The 2.5L has just been purchased, in order to replace the 2.0L because I had major problems after the engine swap I did ( it was originally a 316 and I put the 2.0L engine in it ) and I'm in the process of bringing every last piece of the car to my liking... as the car's general shape and condition was spectacular, not to mention the price I paid for it. ( damn cheap ).
    I wanted to ask something about the ECUs. On the 2.0L one, I have a 172 Motronic 1.3 ECU, with the stock chip and the rev limit up to 6500 rpm. ( i also have another chip that raises the rev limit to 6900 rpm ).
    Today, I felt like placing the stock chip of the 2.0L ECU to the 2.5L ECU. ( Currently, on the -to be sold ASAP- 2.0L car I have the chip that goes up to 6900 ). But when I saw the 325's ECU number I hesitated for a while. It wasn't a 172 or 173 ( I thought those were the only ones... ) and I thought that the chip wouldn't work. And all that fuss because my 325's rev limit is 6100 rpm :(
    The 325's ECU code is 261200380. I don't know any further information about it as I haven't checked the ECU with the appropriate device that does all the scanning for the Motronic version and the car's problems and all that.
    I wanted to ask if I could just swap the ECUs right away ( if such an action is something I should do in order to take advantage of the better ECU between the two ) because I am taking everything that's worth from the 2.0L E30 and putting it to the 325 and then selling the 320. Which one is better and for which car?
    Would there be any problem with gas ignition, fueling and all that? Are the ECUs differently programmed for the 320 and the 325? ( I suppose they are, right? )
    I wouldn't want to do something like that without knowing 10000% if it's right or not, hence I'm asking if someone knew anything.
    Thanks in advance for any help :)
    P.S. Awesome place for our E30s and for bimmers in general, great work :up:
  • a3ternus
    • 643
    Welcome! Obviously you havent read the epic flame wars of the past,but anyway things are much better nowadays in here...:D
    Well,my is that you should NOT do the ECU swap.
    Its pretty self explanatory IMO...2lt and 2.5lt ECUs are NOT
    interchangeable.How can they be really?!?
    N.
    Originally Posted by aaron_silva
    It is always frustrating having a harsh ride when
    you arent in the right mind set.
    • BavarianBimmer
      • 951
      N.
      I've swapped an 172 ECU in with an 173 in an 1990 E34 520i and it runs pretty much the same so no gain
      they are interchangeable
      1989 E30 318iS_______________________________1989 E30 325iC M-Technic I
      1997 E36 328iT
      1990 E30 325iT 24v SOLD
      1989 E30 325i 2.7i M-Technic II SOLD
      • AdamF 88iS
        • 2051
        The basic internal setup of the ECU should be the same since its the same 6 cyl engine setup, but it'll be the programming that's different. This is the case with pretty much all Bosch Motronic ECUs through the generations used in many German car brands during the 80s and 90s.
        Logically, swapping the chip should do it, but I can't say that with 100% certainty. The 380 ECU is still 1.3, but I believe it is slightly updated as compared to the 173.
        Adam Fogg- '88 M3
        Common sense- It's the new 'gifted'
        • BavarianBimmer
          • 951
          Is the 526 ECU also Motronic 1.3 ?
          It should be the last update for the b25 engines
          1997 E36 328iT
          • euro3
            • Aug 2004
            • 761
            2.5 vs 2.0
            I did a swap in a euro 320i a while back, I changed the motor to a 2.5 and re-used the 320 computer without any problems. It ran, idled, and started without problems.
            Also, how did the 316 to 320 swap go? I tried it once and ran into a ton of shit....I finally figured it out after alot of headache
            • AdamF 88iS
              • 2051
              1.3 is the highest base setup that the M20 ever got.
              Adam Fogg- '88 M3
