OEM replacement rear subframe mounts
  • ptownTSI
    • Jun 2005
    • 1265
    they are only like $36 a set, vs $90-$100 a set for polyurethane subframe mounts. is it a really nice ugrade just to put some new stockers on, or should i relaly spend an extra 200% on poly mounts.
    the rear trailing arm bushings might be worth it to do in poly though right?
  • StereoInstaller1
    GAS
    • 22679
    Personally, that is esactly what I am doing. Rubber SF mounts, poly TA mounts, poly sway bar mounts. IE toe and camber kits, reinforcing the TA's.
    Up front, remove some negative camber, poly CABs.
    Keeping it simple, cheap, and more emphasis on comfort over performance.
    Luke
    Closing SOON!
    Thanks for 10 years of fun!
    • AdamF 88iS
      • 2051
      Stockers are fine. If you want, get some liquid resin and fill in the empty areas of the stock bushing so you get a semi-solid type of thing going.
      Adam Fogg- '88 M3
      Common sense- It's the new 'gifted'
      • 1991 318is
        • Dec 2005
        • 786
        Stockers.
        Get a tube of urethane windshield adhesive and fill the spaces of the stockers. You can get it in a tube that goes in a caulking gun. Stiffens up the stockers.
