Can anybody tell me how to take my speedo cluster out, cause I want to paint the needles, and the surrounds of the clocks, could somebody pls help?
Speedo , and clocks ?????
simply remove the trip and unscrew the 4 bolts that hold the tach in place and disconnect the all 4 conectors and the bulbs it would be much easier if u would take ur steering wheel off just remove the bmw logo fom the wheel and loosen the 21mm nut and wala... its easy. -
It's a 22mm nut. :up:Originally posted by E30-330isimply remove the trip and unscrew the 4 bolts that hold the tach in place and disconnect the all 4 conectors and the bulbs it would be much easier if u would take ur steering wheel off just remove the bmw logo fom the wheel and loosen the 21mm nut and wala... its easy.
Be very careful taking your needles off to paint them. Use a fork and put a napkin under the fork in between it and the dials, and very gently pry the needles up.Comment
