1989 E30 325i - Stutters at Highway Speeds
  • Breezeways
    • Oct 2014
    • 10
    My 1989 325i E30 has recently suffered a new problem. When driving at highway speeds (60+ mph) the car will often drop its RPMs and the check engine light will appear on the dash.
    Here is a video illustrating my problem. I'm quite confused because in the description he states that he has changed both the DME fusible link and the crank positioning sensor. This is confusing to me because in this thread the posters give advice to check these two areas because they may cause issues.
    Has anyone seen this issue and how did you go about solving it?
  • dnguyen1963
    • Nov 2011
    • 2649
    That sure looks like the engine is losing its CPS signal. Put in a known working CPS if you have one to see if the problem goes away.
    • Breezeways
      • Oct 2014
      • 10
      I dont. :/
      I was planning on ordering one. I assume I should go ahead and place that order?
      Thank you for responding.
      • dnguyen1963
        • Nov 2011
        • 2649
        Check to see if you have E30 fellows in GA that can lend you one before spending money. There are quite a few E30s in the GA area.
        • Breezeways
          • Oct 2014
          • 10
          I'm not in GA right now because of school and work. However, my dad is. I will ask him to try and find one. Can you suggest any short-term fix? I had to stay at 55mph on the drive to work today else it would cut out.
          • dnguyen1963
            • Nov 2011
            • 2649
            Try to clean the CPS then measure the distance to the toothed wheel. The distance should be 1 mm (use a feeler gauge). Make sure the bolt is tight and the CPS is not moving around.
            • Breezeways
              • Oct 2014
              • 10
              I plan to clean the CPS when I get home today. Do you know where I can find instructions on how to remove it? I couldn't find any information on it in the Owner's Manual authored by Bentley Publishing.
              Yesterday, I checked the CPS and its wire. The CPS is tight and secure. Furthermore, the wire had no leaks or breaks. I think the action to take against the CPS is to clean or replace it.
              What will the distance to the toothed wheel tell me?
              • dnguyen1963
                • Nov 2011
                • 2649
                CPS is basically a magnet. If the distance is off the signal coming into the DME will be incorrect and the spark might be cut off.
                • Breezeways
                  • Oct 2014
                  • 10
                  Update: Tried to clean the Crank sensor. Failed miserably. I couldn't get leverage on the nut and it wouldn't turn. If you have any suggestions, I'd love to hear them.
                  Otherwise, father suggests that I take it to AAA and have them diagnose the issue. I'm almost certain that it is the crank sensor because the problem persists and it wouldn't start after the first turn of the key this afternoon.
                  • dnguyen1963
                    • Nov 2011
                    • 2649
                    What did you use to try loosen the bolt? You need an Allen wrench/driver to break it lose. Do not take your car to AAA. I doubt that they know how to fix an E30. Try to locate a local BMW mechanic.
                    • Breezeways
                      • Oct 2014
                      • 10
                      Used an allen wrench. Space was so tight and engine was hot I ended up burning my hand quite a bit. Not to mention, I couldn't gain any leverage. I will try tomorrow morning.
                      • Breezeways
                        • Oct 2014
                        • 10
                        Went out and recorded a video.
                        You can view the video here. Let me know if the link doesn't work.
                        • dnguyen1963
                          • Nov 2011
                          • 2649
                          Do you have a set of allen driver and a socket wrench? What you have should work. Flip the wrench around then use this technique to help you.
                          • gart
                            • Jul 2012
                            • 295
                            Go get yourself a allen socket set.
                            89 325 cabrio in progress m52tub28 swap
                            99 540it
                            86 Volvo 240 wagon
                            99 Cherokee
                            13 Passat
                            • Seawolf
                              • Feb 2015
                              • 270
                              What's your fuel pressure reading, this could be an ailing fuel pump dropping pressure.
