AKG mono wiper install
  • Brisbane E30
    • Jan 2013
    • 99
    Hello everyone!
    I am undertaking an AKG mono wiper install. My ride is a RHD 1990 318is.
    The linkage that is integral to the AKG kit is very different to the one that I pulled from my car.
    Obviously there is a difference between the LHD and RHD linkages - but my question is whether there is a difference between LHD and RHD as to how the wiper motor mounts.
    For my RHD car there are 3 bolts that come from the floor of the space that the motor mounts to and the motor and its carrier simply slide onto those 3 bolts. Is it the same with the LHD?
    I will take some photos tonight and update this thread with those so that you can see what I am talking about. Any assistance in the meantime would be very much appreciated.
    Thank you!
    E30 318is S50B32 powered
  • ngampleh
    • Jul 2012
    • 466
    LHD wiper lingkage
    hello neighbor country!
    basically AKG monowiper is modified LHD linkage
    here stock LHD linkage
    -LHD lingkage
    >> the motor attached to linkage (on passanger side RHD car)
    >> it have 3 mounting location, 2 under windshield and 1 under the motor
    - RHD lingkage
    >> the motor attached to chassis with 3 nuts
    >> and the linkage attached to chassis, it have 3 mounting location
    2 under windshield and 1 behind battery tray
    this is installed on LHD car
    you need to cut all 3 welded screws that mounted on floor/chassis, use drill and chisel, or other tools that maybe handy to you..
    then you need to make new LHD mounting location..
    if your car stripped, then its easy to do fabrication and welding..
    hope it help..
    [ETA - E30 Adapters] 5 Lug kit with e46m3 front and e46 325/328i rear brake setup
    [ETA - E30 Adapters] - 5 Lug kit | DTM Shifter | DSSR
    Transaction Feedback
    • Brisbane E30
      • Jan 2013
      • 99
      -LHD lingkage
      - RHD lingkage
      hope it help..
      Sensational assistance!
      Thank you very much. I appreciate your help.
      Those photographs give me an excellent view of things. I am going to make some sort of LHD/RHD hybrid from the looks of things. I will see how it goes and will post the results.
      Thank you very much again!
      • TURBOX
        • Mar 2016
        • 138
        cant wait to see it done, just installed one on my LHD, still trying to get the sweep centered
        [1991, E-30 325i, 5-Speed, M20, Brillantrot] [1998, B5 Passat 1.8t] [2007, R6 Yamaha] [2011, Tundra 5.7]
        • ngampleh
          • Jul 2012
          • 466
          is that linkage from AKG or you did modification from stock linkage?
          • TURBOX
            • Mar 2016
            • 138
            no modifications were made during install, It an AKG Mono Wiper Linkage, Re-Used and straightened Wiper Arm, re-used existing motor.
            • ngampleh
              • Jul 2012
              • 466
              Nice...
              My custom linkage sweep more than AKG
              And its parked on center
              • TURBOX
                • Mar 2016
                • 138
                Nice...
                post a pic of the custom linkage, really interested in seeing it, i would like a bit more sweep, and at this point, i actually would go back in just to get it full 180
                • ngampleh
                  • Jul 2012
                  • 466
                  This thread made me to did mod..
                  180deg sweep was impossible..
                  Mine is about 140deg
                  • TURBOX
                    • Mar 2016
                    • 138
                    Darnit
                    that's what I've been reading also (due to motor binding concerns, 180 not recommended)
                    bout the same as mines
                    • e30m3s54turbo
                      • Jun 2010
                      • 3290
                      My are at 180 degrees. No binding on mine.
                      • BaltimoreBimmer
                        • Apr 2016
                        • 307
                        Your AKG is at 180 degrees? Do you have any pictures? I'm trying to picture the end to end positioning on 180 degress.
                        • TimeMachinE30
                          • Jun 2014
                          • 3749
                          I need to revisit this myself.
                          Raul, you said I need to delete the driver side mount.. but in these photos both studs are going through the cowl...
                          I am not getting full sweep with my modified linkage.
                          Need to get this handled before I get too far along (though the motor is already in.. it will be a bear to handle it)
                          ACS S3 Build / Dinan 5 E34
                          • Todd Black 88
                            • Oct 2007
                            • 3449
                            It cannot sweep 180*.
                            If it did, it would sweep off the windshield onto the cowl on both ends. Look where it's mounted, below the windshield.
                            Originally posted by codyep3
                            I hope to Christ you have looks going for you, because you sure as fuck don't have any intelligence.
                            2001 silver/Blk 325 cabby. SOLD
                            2002 325xit Sil/blk. SOLD
                            2010 F650gs twin
                            • superj
                              • Feb 2006
                              • 397
                              yup, no go on the 180 degrees for reason stated above.
                              other than looks, why do you guys go mono?
