mestang injectors
    mestang injectors
    are they a direct bolt on?
    88 528e with 325i head, and ECU etc...manifold tb,etc...so basically a 325i
    i heard you have to cut some wires or something
    thanks
    Direct swap for the "i" injectors .
      wait a min, it has the i injectors on right now, so the mustang ones are a direct swap or the i ones are a direct swap for the e ones?
      they already went from e to i so he wants mustang ones
        Yes thats what I'm saying .
        Mustang 19lb injectors are a direct upgrade/swap if you already are running "i" injectors .
        If you had eta injectors you must first switch to the "i" harness and DME/UCU .
          well with the ECU its a direct plug and play from the 88 528e Motronic 1.1 to the 325 Motronic 1.3. Cause only thing thats different is the head.
          So basically its just an overgrown E30 right now, with a bigger stroke.
          I was just concerned cause he already ordered them and we are going to put a MAF and tuner on his car so we wanted bigger injectors first.
          thanks
