There's a squeak coming from the clutch pedal when I depress the clutch. It only happens sometimes, is it something to be worried about?
Squeaky Clutch
Tags: None
There is probably a lack of lubricant on the shaft that the thowout bearing slides on. May increase wear on the shaft, but not really a major problem.
Mine did that, and I couldnt stand the sound, and thought of it. So I pulled the trans, and greased all the pivots and the shaft
Originally posted by DaNThere is probably a lack of lubricant on the shaft that the thowout bearing slides on. May increase wear on the shaft, but not really a major problem.
Unless of course it's the actual pedal which is what it sounds like it is. The E36 has a well documented issue with a squeeky clutch pedal due to a bushing. The e30 is probabably a similar design.
