AC weirdness
  • Jaybee325is
    • Dec 2015
    • 32
    AC weirdness
    My A/C fan motor will come on while in cranking my car but turns off after I let off the ignition. Relay? Corrosion?
    Also my tach is acting wonky (works sometimes) heat gauge doesn't work. Not stressed out about either. Just don't know if there's a relationship.
    The tach & temp gauge are probably problems in the instrument cluster. I have no idea why the aux fan would turn on while cranking.
    • Jaybee325is
      • Dec 2015
      • 32
      Should have been more clear. I'm trying to get the fan to work. The fan is in the on position. It just cuts out after I let off because the car is cranked.
        What car is this? The operation of the aux fan is different between early and late models.
        • Jaybee325is
          • Dec 2015
          • 32
          88 325ic
            Okay, that means the car should have a three terminal starter. One of the terminals operates the unloader relay, which should prevent the HVAC system, aux fan, and windows from running when cranking. Diagnostic work is going to be required to find/fix the problem. The factory wiring diagrams (http://wedophones.com/BMWManualsLead.htm) will help.
            • Jaybee325is
              • Dec 2015
              • 32
              I'll check it in the AM. Thanks!
              • M_3_X
                • Jul 2016
                • 162
                Just for clarification, are you referring to the a/c blower motor or the aux fan in the engine compartment?
                I see there might be some confusion going on.
                "If everything seems under control, you're just not going fast enough"
                -Mario Andretti.
                ___________________
                River City Bimmers BMW CCA
                2005 X3 3.0i ZPP, Htd seats, Htd strng, Black Sapphire on Terracotta.
                2002 ///M3 Coupe, Steel Gray Metallic on black leather, HK, three pedals.
                1991 E30 325ic, AW, Black Leather, Black top, Three Pedals.
