324td manifold and turbo on an M20?
  • arnib
    • 52
    I have heard so many stories of people that are going to turbo
    their car, start with a 324td manifold but then ditch it for something else.. :hmm:
    Does anybody have personal experience with this?
    Is the td manifold usable, does it need modifications, and if so - which?
    Do you know any specs for the 324td turbocharger? (Garrett T0324?)
    And last but not least, if I use the 324td crank for longer stroke,
    which piston rods / pistons should I use for an appropriate C/R for a turbo setup?
    Thanks! :)
  • skat 325is
    • 296
    The td manifold doesnt match with the head's exhaust ports even if you get it to match the studs\bolts that hold the manifold to the head.
    Order a pro-turbo adapter for stock manifold or custom build yours.
    My custom manifold is being buillt, should be done by wednesday or thursday.
    I'll post pics when its done
