I recently replaced my shifter bushing and shifter because there was alot of play when i was in gear (felt like i was in neutral no matter the gear). This did help a little with the play and made it easier to go into gear, but theres still quite a bit of sloppiness while in gear. Im thinking it must be just a worn linkage and am wanting to replace it to find out.
Before i go buying a whole shifter linkage i may not need, are there any other bushings i can replace that could be worn enough to cause this much sloppiness?
Any info will help
Thanks!
Any info will help
Thanks!
