Hi everyone... I have removed an aftermarket alarm from my early 1987 325i E30 and would like to use again the code function. Right now, when entering a code, the engine starts without hesitation...which is not supposed to! So I must assume either the relay box is not working properly or it was bypassed.
After checking the whole harness, I found out that the OBC high harness, after green connector which plugs to the OBC module ends with a green wire connected to a green-red wire with two white conentors, all together..sort of a loop. But if I unplug this "loop" one of the white connectors may perfectly connect to a similar connector which goes out the Motronic over the glove box. This connector is already connected to a another harness, though but I suspect the my obc relay box is bypassed and should be connected back to this Motronic connector, green, yellow and black cables...
Any ideas? Help is much appreciated!
Cap Alfie
Cap Alfie
