Tach/Obc/Radio not working and a little more
  • Chris Spiegl
    • Aug 2016
    • 155
    So, my 1988 325ix has a handful of electrical problems, that I need some help with. So the PO had an aftermarket radio and amp, but ripped the amp out of the car.
    So when I bought it, the radio doesn't work (no power or anything), the OBC gets backlight but no data, the tach/mpg doesn't work or light up in the back, and the a/c decides to turn off at random times(it'll be blowing air and all the sudden stop)
    I have replaced every fuse, fixed splice 319, and tried a known working cluster.
    Any ideas?
    Thanks in advance
    1987 325is 2.8L Stroker Turbo "Little Pickle aka The Green Turbo Sled"
  • efficient
    • Feb 2012
    • 3312
    Try messing with the wire bundle behind the gauge cluster ( the one behind the gas gauge). The purple wire is the power for the obc, speedometer
    • Chris Spiegl
      • Aug 2016
      • 155
      My speedo worked up until yesterday when i washed my car and i think i shorted out my speed sensor.... oh well...
      Will try the purple wire! thanks!
