This started happening last night, it will let me put it in gear but the pedal will be very low and feel soft. This morning, the pedal would just go all the way down and not let me shift into any gear and the pedal just stays on the floor. What could it be? clutch slave(master) cylinder? If so how much am i looking to pay for this?
Clutch Issue
Tags: None
probably a slave cylinder
since you should prolly replace it if you do a new clutch, check yer fluid reservoir and if its like, well, empty, try replacing the slave cylinder first.
If you get a used slave cylinder, wiggle the piston to make sure it's tight with no play.
get a bottle of clutch fluid, a bleeder, a friend, and follow a diy on bleeding the system, not hard.
