Late 1986/Early 1987 Automatic 325e Driveshaft
  • Maggiolone
    • Oct 2015
    • 56
    Apparently no guibo came on these.
    Are these equipped with a replaceable CSB?
    I'm trying to eliminate a rapid clacking noise that has returned.
  • itsonlygeorge
    • Feb 2014
    • 852
    Yes, the CSB is a wear item. And you should also replace the guibo, they do have them. Some eta's have a vibration dampener as well.
    1987 325e Lachssilber w/ MarkD chip and late bumpers, Zender EVO spoiler, s3.25 LSD
    Originally posted by nando
    I don't think there's really strong evidence that ZDDP harms cats.
    • estoguy
      • May 2013
      • 1087
      But you really don't need the vibration dampener, many ditch them when replacing the guibo.
      Estoguy
      • Maggiolone
        • Oct 2015
        • 56
        No guibo on mine; it's an early 1987 model ETA automatic with the anomaly of not having a guibo, from the factory.
        • itsonlygeorge
          • Feb 2014
          • 852
          Pics or it didn't happen.
          I have a 87 eta that was manufactured in late 86 as an auto and it had a guibo. Now it's a 5 speed.
          • Maggiolone
            • Oct 2015
            • 56
            think the no guibo ds's were used on auto eta's up to about 10/86 build date. no wierd looking substiture, in place of the quibo is a u-joint. they use a 4 bolt flange and are not interchangeable with other ds's unless output flange on tranny is swapped too.
            my 7/86 build eta auto has this config.
            • 1843lamp
              • Sep 2015
              • 276
              More confirmation...I have two ETA's build date 5/86 and 4/87 both are automatics and no guibo.
              • 1843lamp
                • Sep 2015
                • 276
                I just stumbled across this thread and thought I would update.I just had to replace the driveshaft in one of my two cars that both use the no guibo driveshaft .A replacement driveshaft was found using a guibo but when I examined the flange on the transmission I discovered you can not just replace the flange itself apparently you need to replace the entire tail shaft or buy another transmission ,there is very little information for owners of automatic cars so someone may find this information useful since the three universal driveshafts are harder to locate.
                • e30patalohas
                  • Mar 2012
                  • 44
                  I had an 84 eta auto with no guibo as well.
                  • superj
                    • Feb 2006
                    • 397
                    I wonder if my two auto etas have guibos? I know the standards do, they are apart currently and I verified those. I never looked at the autos though.... hmmm
                    • Izaiahrocha33
                      • Dec 2017
                      • 1
                      Recently I tried replacing my CSB and have also noticed the lack of a guibo. Have you guys tried replacing the CSB on a driveshaft like this? Any tips or info on removing the trans side of the driveshaft? It’s a small space and unlike the more common driveshafts where the bolts are facing the rear. My car is an ‘86 325e auto
                      • 1843lamp
                        • Sep 2015
                        • 276
                        I had to do this job 4 times recently,due to a lousy expensive driveshaft rebuild by professionals ,that did not work.All I had to do each time was remove the small single rubber rear doughnut hanger and remove the three bolts holding the front ex section from the rear ,carefully let it tilt downwards ,the driveshaft comes out best towards the passenger side.the center bearing is very easy to replace ,just make sure you mark the two driveshaft halves before you attempt to remove it or you may end up going through what I had to .
