Can't identify smell (no leaks)
  • Mook613
    • Apr 2016
    • 232
    While driving around, when I stop (ONLY with windows open or roof down) I get a whiff of a burning smell. It isn't quite as sweet as coolant, and not as acrid as oil. There is a slightly sweet smell to it and it isn't my heater core leaking.
    I'm not loosing any fluids (save for a tiny bit of oil due to a stripped oil pan bolt and a poor repair job).
    I was told that it may be a compound in my brake pads (manufacturer is Pagid, with Zimmerman rotors) that is burning off. Those pads and rotors were installed several thousand KMs ago.
    If I leave my car running when I get home I am unable to smell it, even with the hood open. It seems to smell for a short time when coming to a stop.
    Any ideas? Am I just being paranoid about an old set of brake pads that may be filled with asbestos?
  • dnguyen1963
    • Nov 2011
    • 2651
    Asbestos are basically glass fibers. There would be no burning smell from them. I suspect that you might have some oil dripped onto the exhaust and burnt off during driving.
    • Das Delfin
      • Sep 2014
      • 2293
      check your valve cover to see if oil is seeping out and onto your exhaust manifold gaskets
