Horn Not working - Troubleshooting Help
  • itsonlygeorge
    • Feb 2014
    • 852
    Heres what I've tested so far:
    1. K2 Relay clicks and works properly.
    2. Horn works when jumping K2 relay pins.
    3. 12v at K2 relay pins.
    4. Fuse #7 is intact and has continuity.
    5. Horn Button works and has continuity.
    6. Touching + and - wires behind horn button does not activate horn.
    It seems like there is bad contact somewhere between the wheel and the fuse/relay.
    What else do i need to check? Do I need to remove the steering wheel? Are there some brushes that are worn out or broken?
    This is an non-airbag 3 spoke "Sport" steering wheel with one large button.
    1987 325e Lachssilber w/ MarkD chip and late bumpers, Zender EVO spoiler, s3.25 LSD
    Originally posted by nando
    I don't think there's really strong evidence that ZDDP harms cats.
  • tomstin
    • Mar 2015
    • 564
    Pull the steering wheel and check the contacts on the steering column. I had a similar problem where those contacts were dirty.
    Mark the shaft and steering wheel. Loosen the nut but DON'T remove it. Sharp pull up and the steering wheel should come loose (if you remove the nut, you'll smack yourself in the face with the steering wheel). Now remove the nut, and remove the steering wheel. Take a look at the contact strip and contacts. Jump it there on the column, if that works, then you have a contact issue between the column and steering wheel.
    2004 525i Manual - 1985 325E Coupe Manual
