I've done some searching with no results. I pulled my fuel tank this last weekend due to rust. In the process of disconnecting the plug assemblies on top, the plastic housings effectively crumbled. They are both 2 wire flat black connectors...1 is for pump power and the other is the driver side sender. The wiring is fine, it's just the plug housings. Would anyone happen to know the part number or alternatively, does anyone have a parts car that you would be willing to cut some pigtails? It's a late model gas tank with 2 senders
Fuel tank electrical connectors
