Can someone please help me troubleshoot the diode that feeds the K1 relay in the fusebox of my '91 318is? My auxiliary fan will not come on when I push the a/c snowflake button. I can jump the K1 and K6 relays and get the fan to turn on low or high speed, but it will not run with the a/c button depressed. The ac button lights up, but I get no voltage into pin 86 of the K1 relay. The simplest answer sounds like the diode in the fusebox, but I am having a hard time getting to it. I can remove the three philips head screws that hold the upper fusebox tray to the lower section, and I can see the circuit boards underneath, but there is a lot of resistance to pulling the upper tray up sufficiently to get access to the underside. Before I break something, is there another fastener, or is this inflexible 30-year old wiring?
fusebox diode
It turns out that the diode is below the circuit board, so I did not need to separate the circuit board from the top of the fuse box. I was having trouble getting the top (with attached circuit board) raised high enough from the bottom of the fuse box to get at the wiring.Comment
Okay, the mystery continues. I now have a known good diode, and good relays. I can still trigger the high and low speed fan if I jump the K1 or K6 relays. I can trigger the high speed fan if I jump the temp switch on the radiator, but cannot trigger the low speed fan from either the temp switch on the rad or the a/c snowflake button (which lights up when depressed). I can ring the radiator temp sensor plug for continuity to the relay, so the wiring seems to be intact. Any suggestions where to look next?Comment
Are you sure you installed the diode in the correct direction?
There is not much to the cct.
2001 silver/Blk 325 cabby. SOLDOriginally posted by codyep3I hope to Christ you have looks going for you, because you sure as fuck don't have any intelligence.
2002 325xit Sil/blk. SOLD
2010 F650gs twin
2016 M235i cabby. Mineral grey/Red leatherComment
