AC / Recirc switch lighting
  • Dustn525
    • Jan 2007
    • 76
    Did a search, can't find a solid answer. Is the switch supposed to light up with the dash lights, or just when you a press a button? I'm doing a dash swap and want everything working right, thanks!
    I do what I want
    Past BMWs: '84 325e, '89 325ic, '92 525i, '91 325ic, '89 535i, '86 325es
  • Das Delfin
    • Sep 2014
    • 2293
    only when you press the button
    • M_3_X
      • Jul 2016
      • 162
      Yes, same as the A/C. Defrost and hazard switches do illuminate with lights on.
      "If everything seems under control, you're just not going fast enough"
      -Mario Andretti.
      ___________________
      River City Bimmers BMW CCA
      2005 X3 3.0i ZPP, Htd seats, Htd strng, Black Sapphire on Terracotta.
      2002 ///M3 Coupe, Steel Gray Metallic on black leather, HK, three pedals.
      1991 E30 325ic, AW, Black Leather, Black top, Three Pedals.
      • superj
        • Feb 2006
        • 397
        mine never did. mine only illuminate when I have them in the closed position
        • Dustn525
          • Jan 2007
          • 76
          I swear the '84 I owned 15 years ago had a switch that lit up just like the defrost and hazards, then got brighter if you pushed a button in. But since then, haven't seen one like it. If you take the switch apart, there's a resistor soldered in there that might have something to do with it. Maybe the resistor fails, causing them to only illuminate in the on position. Oh sh** my OCD is flaring up now...
          I do what I want
          • superj
            • Feb 2006
            • 397
            That could easily be what happens
