Happy Holidays!
I recently picked up a JDM-Spec 1991 325i slick top 4-door automatic with 29,100 miles. Before I begin, I want to get ahead of the inevitable question: why am I putting so much work into an automatic? While I'm a young guy (25), 15 years of competitive (and sometimes careless) cycling and skiing has caused me to develop patellar tendinitis in my left knee, which is my dominant leg. A third pedal is totally manageable on short drives, but spending an hour + crawling southbound on 495 (MD to VA) every night wouldn't be fun.
A little history: for most of its life, the car sat untouched and unused in the basement garage of the original owner's Tokyo apartment building. The owner spent most of his time in Germany but often traveled to Japan for business. I believe this neglect allowed the fuel, which smelled of varnish, to corrode the tank and ruin the fuel system. When driving the car home from the delivery point (5 miles), the valves seized and damaged the head. Piston #2 was kissed, but only slightly. While it is a huge bummer that this happened, Caveat Emptor is a principle that almost always bares its teeth. I've prepared accordingly and decided to go ahead and restore the car despite its less than desirable specification. Fortunately, the car is perfect in every other way so the investment shouldn't be totally pointless. If in the future I grow weary of the automatic and my knee stops being a jerk, maybe I'll give it the Getrag 260. Only time will tell!
All of this work is being completed by RRT in Sterling, VA. While I love to wrench, I was nervous that my relative inexperience with e30's would ruin the car. On the positive, it's nice to establish a legitimate paper trail detailing the rebuild, which I expect would make a future sale easier. On that note, I'm hoping you all can let me know what else should be done while the car is apart or if you have any other recommendations for future updates/modifications. I'd like to keep the car original as possible, save wear items. You all know better than me, so whatever knowledge you can pass my way in regards to shunned e30's would definitely help!
Here's whats been done/about to be done:
Head:
Machined + 3 angle valve job
TRW intake and exhaust valves
BMW Rocker Arms
BMW Complete Head Gasket Kit
Timing:
ECS Timing kit w/ Gates Racing belt
Ignition:
Bosch W8LCR plugs and rotor
Bremi Ignition wires and cap
Fuel:
Siemens Fuel Pump Assembly
Siemens Right Fuel Sending Unit
BMW Left Fuel Sending Unit
Spectra Premium 16.6 Fuel Tank
Drive line:
4.10 LSD pumpkin swap into 4.10 Open diff
Driveshaft Bearing
Transmission Mount
Steering:
Rebuilt e30 Steering Rack Assembly
Tires:
Michelin xIce xi3 185/70r14 on OE Basketweaves
Whats to be done in the future:
Suspension:
Bilstein B8 Inserts
H&R Sport Springs
Brakes:
They weren't great when I drove the car home, but worked nonetheless. Booster works fine, a vacuum issue might be present. Hopefully the pads are just awful and only needs a basic rotor/pad/fluid tune up.
Exhaust:
Does anyone make a midpipe/connecting pipe to the header for these cars?
So, what else? Thank you all very much!
