Today the low beams on both sides work but when the high beams are turned on both the high and low beams on the drivers side work but neither work on the passenger side. Is it just that my passenger side high beam needs replacement?
Recently the wipers only seem to work after turning them on and then making one very gentle tap on the tip of the stalk straight in towards the steering column. Is the stalk in need of replacement or is something loose?
Any ideas are welcomed.
