Steering squeek with momo hub on airbag column
  • e304me
    • Feb 2006
    • 1374
    anyone had this problem?
  • e304me
    • Feb 2006
    • 1374
    i grabed the white spring loaded think sticking out of the column with some pliers and ripped it off and the noise is gone
    • KangamangusDriver
      • Aug 2005
      • 1870
      Did you lube any parts that are moving/touching. I had the same prob with mine. A little grease took car of it.
      • delatlanta1281
        Dart Master
        • Mar 2006
        • 10317
        No you didn't.
        Yours truly,
        Rich
        you kids get off my lawn.....
        • e304me
          • Feb 2006
          • 1374
          uh, yeah i did. does it have a purpose?
          • ZinRot325i
            • 291
            Errr was it on the bottom or the side?
            If it was metal and on the bottom, your horn doesn't work anymore.
            If it was on the side and plastic, maybe your turn signal will no longer turn off going around a corner.
            :wgaf:
            • e304me
              • Feb 2006
              • 1374
              no was on the top. IT was a white shaft sticking straight out
