Trying to remove the left rear window regulator from a 91 318i.  It's stuck in the "up" position. As you might know, there's no provision to manually crank the late-style motors with an allen key.
I've applied 12v directly to the motor using jumpers from the battery to try to get it moving. I’ve even done this while smacking the motor with a tool to coax it. No dice. The motor seems seized, and I certainly can't move the cable by hand.
I was able to remove one of the two bolts that hold the glass channel, but the front-most bolt remains. And is in a very tricky position to try to get a wrench on. With the rear bolt removed, I can move the regulator around a bit, and the glass can even drop about 1/2" but it's still eluding me as to how to get this front bolt off.
Can anybody sell me a clue or trick??
