Hey guys,
Recently i had a interesting failure - my tachometer failed (Speedometer works), it would start working and fail sometimes (Bouncing like that) and now its completely dead. With it - the interior lights failed, they would also flicker with the tacho when it was working, same with the 6-button OBC, it also is not working, it just wont show time or anything at all, it does flicker thought, but 0:00, like it's missing a ground or something.
It might also be that all of that took an oil light with it, since i cant get it to light up after a cold start or on ignition.
Is there any common failure that could take all those things at once?
Thank you,
Max.
Thank you,
Max.
