So I removed the clutch fan and using the aux fan as a cooling fan. My AC is also removed. I just installed a m42 80 c aux temp sensor but the low setting is not cooling enough for my comfort. I would like the aux fan to turn on high instead of low. I know the black wire is ground but not too sure about the other two. Do i just cut the two colored wires and switch them?
Sent from my SM-J700T using Tapatalk
