Blown fuse from rolling down same side of the window?
  • cspec
    • Apr 2017
    • 182
    Hey guys, for some reason my windows fuses keep going out.
    If I roll down the drivers and passengers at the same time, it doesn't blow.
    But!
    If I roll down the passenger front and rear windows, it blows. Any ideas?
  • tomstin
    • Mar 2015
    • 557
    Is one of the windows slower than the other? My guess is one motor is overloading the circuit. Lube the tracks.
    2004 525i Manual - 1985 325E Coupe Manual
    • cspec
      • Apr 2017
      • 182
      Now that you bring it up, it is a bit slower. I will try that and report back. Thanks!
      • ELVA164
        • 4861
        You should be able to lower all four windows without blowing a fuse, so lube the tracks and you may want/need to clean the brushes on the motor itself too.
        • Das Delfin
          • Sep 2014
          • 2293
          it sounds like your passenger rear window motor may be on its way out. When motors age, they draw more current than normal, which is what's causing your fuse to blow
          try to make sure it's the rear passenger by trying different combinations of windows together
          • cspec
            • Apr 2017
            • 182
            Thanks for the reply!
            Damn... I guess I should start getting a new motor ready. Do you know if motors are the same for the cabrio/coupe/sedan?
            • Das Delfin
              • Sep 2014
              • 2293
              ^ I don't know if they are. But before you buy definitely try to isolate that window in particular as having a fault. And if you can, source a new motor from a junkyard to save money
              Might also be worth your time to try a new switch, or move the switches around to find one that consistently blows. Do all this to justify the purchase so you know it's going to fix the problem
              • tomstin
                • Mar 2015
                • 557
                I had another thought. You didn't mention the year, but as I recall the early models (like I have) the power window track is a tube with a spine going through it and they tend to get gummed up.
                First I would spray some silicone on the tracks you can see. If that doesn't help you will need to remove the door card, disconnect the motor and remove the track. It takes a LOT of patience to get the track out of the door. I'm sure there is a how-to online. The motor comes off with three screws on a plate. Make sure that spine moves freely through the tube. If all that moves freely, then you motor is showing its age. There is another post someplace on cleaning the motor contacts.
                • cscracker
                  • Jan 2017
                  • 131
                  If yours hasn't been maintained in a while, the tracks are probably dry as a bone. Use silicone lube and soak the tracks until they soften up and move smoother. If it's been a long time you might even use a whole can to get all four windows.
                  For the mechanisms and motors, mine were seized up. I hit them repeatedly with lots of PB blaster (and a hammer), they freed up and work pretty well now. If I don't use them for a while they still tend to stick, but holding the button and hitting a bump in the road usually frees them up. I'll probably hit the motors with some electronics cleaner spray and re-lube the mechanisms with silicone next time I have the door panels off.
                  • cspec
                    • Apr 2017
                    • 182
                    Mine's a 1990, is that an early or late year?
                    Do you lube them by taking off the door panels, or just spraying down the sides?
                    • cscracker
                      • Jan 2017
                      • 131
                      1990 is a late year.
                      You lube up the track by rolling down the window and spraying the slots on the sides, but if your mechanism is crusty too, you'd take off the door panels to get to it. Start with the track, see what kind of results you get, if you still have trouble, then remove the door panels and check out the motors and the mechanism. Be very liberal with it, soak them, roll the window up and down a few times, repeat until it moves fast again.
                      • cspec
                        • Apr 2017
                        • 182
                        Appreciate it!
                        • cspec
                          • Apr 2017
                          • 182
                          Just an update, I lubed them, and they are much smoother, but it seems the rear passenger window still blows a fuse. I will take it apart and then hose down the motors and mechanism with more lubricant later. Hopefully it will work!
                          • tomstin
                            • Mar 2015
                            • 557
                            Probably not a good idea. When you get the mechanism out, take the motor off and make sure the track itself is free. My guess is that is your issue. But, there is a post around someplace about how to take apart the motors and clean the contacts.
                            • cspec
                              • Apr 2017
                              • 182
                              Could you elaborate what you mean by the track itself is free? Wouldn't it be free if I can roll the windows down? It just blows after two uses... Now one.
