Hello to all ....
1988 325iC E30..Cooling Switch is on the right side 3 Prong...
Was trying to get the Aux fan Cooling Switch to work.High speed works but low speed doesn't and jumped the usual color for high and low speed.
But as i was putting back the inside headlight cover,which is a tight fix
As i was putting the plastic male plug in the Cooling Fan Switch the plastic housing cooling fan switch turn around about 1/4 turn "with a little bit of drag"so the wires wouldn't interfere with the inside headlight cover.This is brand new and installed last year..
Is this normal for it to turn like that.....
And
if it's this is normal to turn can i check to see if it's still good while in the radiator and to see if high and low speed works...
And
One more question and reading a lot on the issue but when they say to this check...do i check while the fuse in still in the fuse box and use my volt meter with the black and red prong right on the fuse box femal sockets or the fuse itself....
Turn the ignition to run and check for voltage on both sides of fuses 19 and 20. The voltage should be essentially the same on both sides of the fuse. If not, replace the fuse.
and all of this ...
Check for voltage on socket pin 30. It should be hot at all times.
Do i turn the key to run On not started to do this test and touch the body as ground.....
Frig i should start my own thread on my car...
And
And
and all of this ...
