Anybody have problems with these ECU's causing eratic idles?
153 ECU's
Tags: None
I went from a 173 to a 525 and think it improved.
Sarcasm is a body's natural defense against stupid.
When a man talks dirty to a woman, it's sexual harassment. When a woman talks dirty to a man, it's £3.95 per minute.
"My mother never saw the irony in calling me a son-of-a-bitch." Jack Nicholson"
Old age and treachery will always overcome youth and skill.
153 has been know to cause erratic behaviour. Many people have switched over to the 173 ECU and been very very happy.Comment
Just swap out the ecu and you're done
You'd need the whole 173 ecu.
I've switched my 153 whole unit for a 173 whole unit for this reason, but the car will not idle, and will die if gas is not applied. Does anyone know how I can fix this?Comment
1995 Porsche 993 6 speed
2001 BMW M3 6 speed - DD
2001 BMW 530iA Sport - Hers
2005 KTM 450EXC 6 speed
Gone:
1988 BMW M3 2.5 EVOIII Clone
1988 BMW 325is x2
1985 BMW M635CSI 286hp
2001 KTM 400MXCComment
Back in the day I had a 153 ECU. I tried swapping for a 173 but the car did not run...well it did, just not very well.
Some claim it is a direct swap, but I have seen others claim that you needed to rework the wiring harness. Hell, I think I even saw an article about reworking the harness for a 153 to 173 swap at one point.
I eventually gave up and kept the 153 until I swapped engines.2004 SL600 - Current
2006 SL55 AMG - Sold
2004 M3 SMG - Sold
1999 540i Sport - Sold :(
1989 325i coupe- Sold
1988 325is M50 M-tec - Sold :(Comment
87 325iC came with # 153.
some what rough idle., bad o2 readings, ecu fault code 1221 (bad o2 sensor)
randomly started to buckle between 3500 to 4500 rpms, it would happen now and then, it progressed to an almost daily issue, eventually it almost left me stranded., limped it home.
I already had a 173 unit at hand, so swapped it out and all is well.
basically the 153 burned away gradually.
iComment
