Blower motor noise
  • bimmerR75
    • Jan 2016
    • 251
    Blower motor noise
    My blower just started making noise yesterday, barely any noise whatsover when on fan setting 1 or 2, but sounds like this (NOTE: not my car, but video is identical to the noise) on setting 3 and gets louder on 4. Does this warrant a complete replacement on the blower motor, or is there another fix? In addition, although if I have no noise on 1 and 2 fan settings, if I "close" the vent with the damper switch, i get the noise.
    If I had to live my life over, I'd live over a Saloon" - WC Fields
    Garage
    1991 325i
    1972 R75/5 Cafe
  • vpilarrt
    • Jun 2006
    • 2096
    Either something (twig, small animal) is rubbing the fan impeller or, like mine, the ring that supports/stiffens the ends of the impeller blades has broken allowing some vanes to deflect under high load and rub the housing.
    • roguetoaster
      Biggus Tippus
      • 7829
      Sounds like a broken fan cage to me, and while a few people have swapped them out it's probably going to require a replacement fan unit.
      • M_3_X
        • Jul 2016
        • 162
        You'll have to Open it up and see. It sounds like one of the impeller blades has broken inside the housing.
        "If everything seems under control, you're just not going fast enough"
        -Mario Andretti.
        ___________________
        River City Bimmers BMW CCA
        2005 X3 3.0i ZPP, Htd seats, Htd strng, Black Sapphire on Terracotta.
        2002 ///M3 Coupe, Steel Gray Metallic on black leather, HK, three pedals.
        1991 E30 325ic, AW, Black Leather, Black top, Three Pedals.
        • JIM1inWisconsin
          • Dec 2014
          • 116
          blower
          Looks like a new blower is needed. Very common problem with E30's.
          • ajp340
            • Mar 2016
            • 62
            Yup, you have broken blower fan blades. Good luck putting that FUCKIN SHACKEL on, its a bear. Be careful not to bend it if/when you use tools to remove/put it back on.
            Out of all the hours of work I have done on my e30 from exhaust manifold heat shield to replacing the control arms to fixing the A/C that FUCKING SHACKEL has been, by far, the worst.
            Good luck
            • ajp340
              • Mar 2016
              • 62
              Good luck
              bump
