Thermostat Choice
  • RL 325i
    • 129
    Thermostat Choice
    some of you might know I failed Smog because of extreme high NO measure.
    I am already looking into getting a new cat, O2 sensor, plug, coolant, TB etc... pretty much a major tune up.
    I notice that the temperature of the car after driving 30 minutes. it only reach 1/4 of the mark.
    Someone I talked to suggested one of the high NO reading is because the engine runing too cold. He said my normal temp reading should be half mark. He suggested that I should replace a hotter Thermostat.
    I am about to order it on line. they listed 3 temperatures. 71,75, and 80 degree. Which should I get to get my car run hotter.
    Help pls.
    Ron
  • AdamF 88iS
    • 2051
    80*.
    Get the car REALLY hot on the way to the smog check place. The hotter the catalyic converter is, the better. High NOx on these cars is a sign that the cat is going.
    Adam Fogg- '88 M3
    Common sense- It's the new 'gifted'
    • AdironRider
      • Dec 2004
      • 3491
      80 degree x 2. No need for anything else with a lower temp.
      Back to my roots
