gas gauge not working in 88ix
  • 2002jm
    • Sep 2005
    • 2073
    My 88ix gas gauge is not working. I switched the cluster in the ix to my other e30 and the gauge worked fine, so I am pretty sure the cluster is fine. I put the working one from my other e30 in the ix and it did not work....
    I have 11.8 volts to the sending unit; float is moving up and down. I took it out and I could hear it move up and down.
    Should I assume the float is just shorted out and not working, or am I missing something like a ground, fuse, or something else?
    thanks for any help,
    jm
  • 101
    • Jul 2011
    • 764
    Have you checked both floats? I believe they are connected in series, so if one or the other is disconnected you won't see anything on the gauge.
    101
    The E30 collection:
    1987 325es M52 - Schwarz / Taurus Red Sport (son #2's)
    1987 325is - Delphin / Black Sport (son #3's)
    1987 325i Convertible - Triple Black
    1989 325iX Coupe - Diamondschwarz / Black Comfort
    1990 325iX Coupe - Sterling Silver / Grey Sport
    1981 Fiat 124 Spider 2000 - Green / Tan
    1998 Volvo V70 GLT - White / Tan
    1998 Volvo S70 T5 manual - White / Taupe
    2001 Ford Windstar - Silver / Grey (parts hauler)
    2006 Lexus GX470 - White / Tan (tow rig)
    • 2002jm
      • Sep 2005
      • 2073
      both floats?
      When I took it apart I only saw the pump and the float. It was a long silver tube next to the pump. Is there a float inside the pump too?
      thanks for the reply,
      jm
      • 2002jm
        • Sep 2005
        • 2073
        I checked the driver side
        So I checked wiring for both sides. Tomorrow I will check continuity for both.
        thanks,
        jm
