i have 1984 bmw 318i and i failed smog twice.........
the first time i got gross polluter and was given advise to change the cat so i did..... here are my readings for my first smog test https://ton.twitter.com/1.1/ton/data...1/hbfLS5VG.jpg
i was also having overheating problems at the time and wanted to upgrade to a later model radiator and swap an electric fan for the clutch fan..... so i did this aswell ........my car runs amazing now. no problems
so i swapped the cat out for a new one and made sure i had no exhaust leaks i went to the smog and was told i couldnt have the electric fan to a toggle switch ("reason i failed smog") i was told my check engine light doesnt work and my evap failed aswell! my readings for second smog: https://ton.twitter.com/1.1/ton/data...9/drfwc4P1.jpg
Since all this has happened i tightened a hose clamp on the fuel filler neck since it leaks when i fill the gas tank all the way up and i believe it wasn't keeping pressure but i think there still might be something wrong with the evap system
now for the check engine light i take out the cluster changed the bulbs that did nothing....but one thing that ive noticed is that when i flip the key for the ignition the parking brake light comes on so does the brake lining and the battery light... correct me if im wrong but i believe that most of the lights on the cluster are supposed to come on but they dont.... tomorrow im going to check a ton of things but hopefully someone can give me a simple solution to my problem
i love this car and want to pass smog so ican keep going with my build!
I have the bentley manual and thats where i get my info but id love to get some help from you guys!!!!
