Exhaust mid section
  • AngeloF10
    • Dec 2015
    • 191
    Exhaust mid section
    Is this a resonator? Or Cat? Does this get replaced with a cat back exhaust?
  • agent
    Vice Grand Pubaa
    • 7960
    Please post your questions in the correct subforum. If you don't know where to ask your question, post it in General Technical and we'll move it to the appropriate subforum if necessary. Thanks in advance.
    Originally posted by kronus
    • BaltimoreBimmer
      • Apr 2016
      • 307
      It's a catalytic converter. RealOEM Link. A cat back system is the part of the exhaust starting from after the last cat going to the muffler. So no, a cat-back will not replace it.
      That part you are showing there is actually just a heatshield over the cat itself. You can see some of the heat fibers sticking out. I had a similar issue on my car albeit not as severe. I simply removed the shield altogether. I would not recommend that, as it definitely serves a purpose. It's just too expensive to replace entirely for me at the moment.
      before removal:
      after removal:
      now come to think of it, I have been having a funny smell, I'll have to check if it's coming from that area. I doubt it, but figured I would mention that here instead of pretending it's not happening. I have driven it for just under 2000 miles like this. I also didn't remove the stickers on my Bosal exhaust before putting that on (ugh, why do they always seem to plaster difficult to remove sticky stickers all over my parts :( ) so it could also be that. Although I'm positive that ish has burned off by now....
      • AngeloF10
        • Dec 2015
        • 191
        Is the shield a part I can purchase separately?
        • BaltimoreBimmer
          • Apr 2016
          • 307
          It is not.
