reving problem
    reving problem
    All right i have swaped a i motor in my eta it runs great, but when im pushing down the throttle just a little bit it will climb in rpm's any higher the motor cuts out. and then when i floor the pedal the car only 4000 rpm and then acts like there is a rev limiter there.
    what do you think it would be?
    fuel pump.
    '89 Alpine S52 with goodies
      crank sensor
        if it rews up well and at higher revs it has problems first of all check the fuel pump... u may install the 3.5 engine pump, it lasts longer and pumps more fuel :)
          My car has a brand new pump (its an m10) and it hits what seems to be a rev limiter @ 4500rpm... could my tack be off?
          "If your going to make a mistake, make it a 100mph."....."But only on the racetrack".....
            well i fixed the problem it was the maf thats all
