M42 overheating at idle/low rpm, lose heat
  • sepehr
    • Oct 2005
    • 57
    My 318is starts to get hot slowly when idling/stop and go/climbing a hill at low rpm. Cools down quickly if I rev the engine it up above 3000 rpm.
    The heater is the opposite: I have heat at higher rpm on the highway, lose heat at the stop light.
    I have a new waterpump in, and changed the thermostat a few months ago; both were attempts to fix this problem. No cigar. System has been bled, rebled, then bled a few more times.
    Any suggestions?
  • craig4ie
    • Sep 2006
    • 359
    sounds like something's restricting the flow, if there aren't any bubbles in the system then it could be a partially plugged rad
    1991 Diamantschwarz 318is
    1998 Cosmosschwarz M3 Sedan
    • volgapower
      • 161
      check the thermostat, it might not be opening at a right temp, or even at all... it might be jammed... ;)
      • DanielHStout
        • Jun 2006
        • 294
        I would have your radiator tested.
        1989 325iX
        1995 540i
        1986 325eS R.I.P.
        1984 325e R.I.P.
        • e304me
          • Feb 2006
          • 1374
          did you overheat recently? how high does the temp get? is there a fan and shroud on the engine?
          • sepehr
            • Oct 2005
            • 57
            The fan and shroud are on, the fan clutch works.
            I had the rad flushed by a reputable BMW mechanic (Nixon Automotive in Burnaby, BC) about 9 months ago, and I think I remember them saying it was OK. Hopefully there isnt a restriction in the engine coolant passages.
            The waterpump DID improve things a tiny bit, as the old one had a somewhat degraded impeller. Then again I might be imagining things.
            I'll take another look see at the thermostat.
