testing fuel sender / gauge
  • jakeb
    • 1909
    Is there a way I can test the fuel gauge? Trying to see if the problem is with the sender or with the gauge...
    Can I ground the wire from the sendor or connect a certain resistance to the sendor wire?
    TIA,
    Jake
    www.classicdaily.net
    1970 m42 swapped 2002
    1985 LS1/T56 Swapped e28 (557e)
    www.blunttech.com - For all your parts needs
    Follow me on Instagram for constant build updates @classicdaily
    https://www.facebook.com/ClassicDailyLLC
  • lordofthewaters
    • Oct 2005
    • 714
    What is the problem? Just the gauge not working? Or is it jumping? Maybe we have some input on the original problem.
    Sarcasm is a body's natural defense against stupid.
    When a man talks dirty to a woman, it's sexual harassment. When a woman talks dirty to a man, it's £3.95 per minute.
    "My mother never saw the irony in calling me a son-of-a-bitch." Jack Nicholson"
    Old age and treachery will always overcome youth and skill.
    • jakeb
      • 1909
      The gauge isn't working at all, sits all the way at empty. Nor is the speedo.
      Actually the speedo did jump up to around 20mph yesterday and then back to 0, it worked for a split second.
      The tach and temp gauge work fine tho.
      This car sat for sometime....probally close to 3 years. Just fixing all this little stuff now.
      The PO had actually installed front brake pads on the rear....it was interesting the lengths he went to, to make them work.
      • lordofthewaters
        • Oct 2005
        • 714
        Well. Lets see. That speedo issue sounds to me like the circuit board has cracked in the cluster. As far as testing the sender I've not heard anything about proper voltages, but I suppose you can test for continuity.
        I'd get that rear brake situation fixed right before I drive much.............
        • jakeb
          • 1909
          The brakes are already fixed
