So I'm getting a lathe.....
  • Z3Jonathan
    • 289
    Delrin is stiffer than urethane I believe. Its similar in appearance and feel to nylon.
    EDIT: a half decent site with some explanations: http://www.suspension.com/bmw2.html
    Jonathan
    • AndrewBird
      The Mad Scientist
      • 11897
      Hell, I could make bushing like this too. Maybe Jordan and I could do together and make a set. That way we wouldn't have to machine so many parts, just hal of them. :) ;)
      Andrew
      • george graves
        • 19992
        Jordan you need to check out some of the homemake CNC machines on the internet...
        Originally posted by Matt-B
        • m42technic
          • 1056
          Jonathan
          Delrin probably wouldnt be too great for street use.
          James Peacock
          WWFSMD?
          • Z3Jonathan
            • 289
            Jonathan
            For suspension: no it wouldnt (not unless you WANT to rattle all your teeth out). For stuff like shifter bushings, seat bushes, etc, it would.
            • Sean
              • 5793
              How bout a fix for that bitch clip?
              I still need to look at that, but its something I plan on doing. Could you machine something that would fit right in that?
              I'd probably be interested in urethene bushings too.
              - Sean Hayes
              • Charlie
                kid tested, administrator approved
                • 6686
                Originally posted by Brian 89 325i
                What ever you can think of i guess. Im sure there is a market for all the common bushings, you could probably make a killing on M3 offset CA bushings in urathane.
                Brian
                Depends on how much you can get quality urethane for. Bimmerworld sells the powerflex bushings which are pretty nice for 59 bucks OEM or 69 offset.
                -Charlie
                Swing wild, brake later, don't apologize.
                '89 324d, '76 02, '98 318ti, '03 Z4, '07 MCS, '07 F800s - Bonafide BMW elitist prick.
                FYYFF
                • darien28
                  • Jan 2004
                  • 240
                  urethane is cheap as fck... I have been researching the possibilities..
                  I have access to large machine lathes, mills, and drill presses with digital readouts and the such. I can help if you guys want. urethans will be a since to lathe out. I can make my own cutting bits as well so I can pretty much make multiple surfaces on a lathe pretty fast.
                  just lemme know.
                  best way is to skip the normal bushings and go straight to the offset. just buy 1 set of the bushings, and I can mass produce them for cheap. i mean... if they have bar stock urethane or delrin the same EXACT size as the powerflex ones, then all we have to do is cut and drill holes... >.> sounds cheesy but that's how it is...
                  • m42technic
                    • 1056
                    Jonathan
                    True.
                    James Peacock
                    WWFSMD?
                    • Z3Jonathan
                      • 289
                      just lemme know.
                      You can buy bar stock delrin.
                      • darien28
                        • Jan 2004
                        • 240
                        i know i can buy bar stock delrin, but whether or not they have it exactly the same size or not is another thing. but it'll only take a few min to turn down the dia of a delrin bar anyways....
                        • RedBaron86325
                          • 386
                          I can make my own cutting bits as well ...
                          Can you turn a drawbar MT3 to R8 3/8" end mill adapter for me?
                          Don't forget the good things Hitler did.
