91 motor into an 87
  • Hawaii87
    • Apr 2006
    • 14
    91 motor into an 87
    So my motor died and my friend gave me his old motor. (He's doing an S50 swap) Both are M20B25's. What all would I need to do this swap?
  • Erick
    Official R3V Drifter
    • 11169
    Edit: Eh... misinformation's a bitch. I keep forgetting '87s still had the older Motronic.
    ..::Support FullOpp::..
    FullOpp Stickers for sale!
    Feedback Thread
    • AdamF 88iS
      • 2051
      Water pump and hoses are different and must be downgraded to the 87 style system.
      Idle valve, intake boot, throttle body, fuel rail, and wiring harness are different but can be used on without swapping.
      Adam Fogg- '88 M3
      Common sense- It's the new 'gifted'
      • Hawaii87
        • Apr 2006
        • 14
        Originally posted by rwdrift
        parts-wise? nothing. I'd do timing belt, tensioner and waterpump while the donor motor is out.
        Is there a difference in the Motronic units and the harnesses? Asking because just looking at them, they look to have different connectors on the motor.
        • Erick
          • 11169
          Yes there is... look above. I read '87 but it didnt click that you had the older Motronic.
          Feedback Thread
          • James Crivellone
            Head Janitor
            • 6305
            The 87i harness is Motronic 1.1 - 1.3, same as the newer 88+ harness.
            The ECU's interchange fine, so nothing is "older" about it.
            Use the 87i harness on the motor, everything will fit fine on the injectors once you remove the injector harness rail.
            You can use the 91 harness if you want, but you will need to rewire C104 into C101, which is dumb if you already have the 87i harness.
            • BENdashdash
              Tom is not my friend
              • Aug 2004
              • 2506
              JC, what the flip were you doing lastnight?
              • Hawaii87
                • Apr 2006
                • 14
                Thanks for the info. I guess I'll have to take a closer look at the 87 harness and the 91 motor again this weekend. I hope it all works, so I can get the car back on the road.
                • Hawaii87
                  • Apr 2006
                  • 14
                  So should I use the 87 harness with a 173 DME??? or keep my DME?
                  Thanks!
                  • StereoInstaller1
                    GAS
                    • 22679
                    I have a 173 DME in my '87is...
                    Swapped from a 153.
                    Luke
                    Closing SOON!
                    Thanks for 10 years of fun!
